I took the runner grommet on the maf connector harness side out. Prayed the pins a little forward as suggested, they all sat flush and pushed them down a little so they would clamp better. Cleared code 12 did not fix I can't get a reading when maf is plugged in the paper lip method must of be penetrating, with maf unplugged I do get .28 from signal wire and that does not change with revs. Or engine heat. I think the ecu has a problem. Wish i kept my na to test. I did not have a ground on wiring harness properly hooked up on back manifold and this cooked the ptu. Tightened ground swapped ptu then car would start. I think this may have affected ecu as well that is the only idea I can think of. Thanks for all of your help I'm going to take ecu cover off tonight and see if I see any burns ll reuept nept aq
